19 years agocommunication ethernet between two FPGAs
Hi to all, I'm a new member of this forum, which, I'm sure, will be very usefull for my problem. So, I'm working with two Cyclon II fpga connected each other by the ethernet cable and I'm tryi...
19 years agoIs there any way to know where the heap is implemented and what I am allocating there?
Actually my application is still very little, and there are hundreds of files inside the syslib allocating something. Then, do you think it is possible to fix the problem freeing some memory space? Like using, for instance, the "standard" sopc model instead of the "full featured" one? When I tried the socket server example I used the full featured and I didn't have any problem.
