19 years agocommunication ethernet between two FPGAs
Hi to all, I'm a new member of this forum, which, I'm sure, will be very usefull for my problem. So, I'm working with two Cyclon II fpga connected each other by the ethernet cable and I'm tryi...
19 years agoThis memory is certainly allocated on the heap. The heap would also hold you static storage and global storage. This is allocated at link time before any alloc() gets a chance to have a bite of the cake. Check what you are allocating there. Maybe you can slim down somewhere.
