19 years agocommunication ethernet between two FPGAs
Hi to all, I'm a new member of this forum, which, I'm sure, will be very usefull for my problem. So, I'm working with two Cyclon II fpga connected each other by the ethernet cable and I'm tryi...
19 years agoSeems you lack free memory: From file ip.c
you see... --- Quote Start --- #ifdef IP_ROUTING /* alloc space for the route table */ rt_mib = (struct RtMib*)RT_ALLOC(ipRoutes * sizeof(struct RtMib)); if (!rt_mib) { # ifdef NPDEBUG dprintf("IP_INIT ERROR: can't alloc route table\n"); # endif /* NPDEBUG */ return(ENP_NOMEM); --- Quote End ---
