Cold Temperature Issue
- 2 months ago
Hi Asaf,
Good to hear that you solved the issue. Yes, all the configuration signals are sensitive can't let the voltage drop even few microseconds.
HI Asaf,
No that is not normal. MSEL is a fixed connection either HIGH or LOW only. It should not toggle during configuration.
Please connect MSEL pin directly to VCC for HIGH, and directly to GND for LOW setup. Dont control the MSEL.
regards,
Farabi
Thanks Farabi,
The issue is after configuration I see the MSE2 is rising to 1.8V, seemed it by the FPAG, is it normal?
Can it harm the pin?
Asaf
- Farabi_Altera2 months ago
Hi Asaf,
Do you have further question?
regards,
Farabi- Asaf_Bloch2 months ago
Hi Farabi,
Thanks for your reply,
No further question,
It seemed the configuration failure at cold temperature cause by voltage translator of the nSTATUS signal,
The following is summarized of the FPGA cold start issue finding:
The design:
nCONFIG and nSTATUS signals pass trough voltage translator 3.3V to 1.8V, this translator is an Auto-direction sensing, when it detects rising or falling in one side it pulls the other side to proper state.
Finding:
We observed that during 1.8V ramp up many signals connected to the FPGA pulled high or low for few micro- seconds – see below.
(1.8V = Vccio_SDM – FPGA SDM voltage)
After our understanding that the issue is not because the nCONGIF signal, we examine the nSTATUS signal.
In normal operation nSTATUS should rise during power-up and then follow the nCONFIG signal.
It should not pull low during power-up by external host.
In cases the configuration failed we found that the nSTATUS is stack low, the reason is that the translator detect the nSTATUS falling during start-up and pull it low, if we change the pull-up resistor on the nSTATUS signal from 10K to 1K the translator is not able to pull it low and configuration succussed.
Failed configuration
Configuration succussed with 1K pull-up on nSTATUS
Hi Asaf,
Hi Asaf,
After configuration MSEL is not sampled. So we dont care the status after configuration. but normally the status will not toggle(normally MSEL hardwired to either VCC or GND-this is stable HIGH or LOW). Still this observation is not normal.
Can it harm the pin- basically no harm, unless the voltage or current exceed the recommended operating condition(buffer damaged due to overstress).
regards,
Farabi
