Cold Temperature Issue
- 2 months ago
Hi Asaf,
Good to hear that you solved the issue. Yes, all the configuration signals are sensitive can't let the voltage drop even few microseconds.
Hello Farabi,
The 3.3V ramping because there are pull-up resistors connected to the system 3.3V, it is low voltage level,
Anyway I moved it and it did not change the cold issue.
I notice the MSEL and nconfige signals are pull up and down during Vccio_SDM ramping, is it normal behavior? See attached
Asaf
- Farabi_Altera2 months ago
HI Asaf,
No that is not normal. MSEL is a fixed connection either HIGH or LOW only. It should not toggle during configuration.
Please connect MSEL pin directly to VCC for HIGH, and directly to GND for LOW setup. Dont control the MSEL.
regards,
Farabi
- Asaf_Bloch2 months ago
Thanks Farabi,
The issue is after configuration I see the MSE2 is rising to 1.8V, seemed it by the FPAG, is it normal?
Can it harm the pin?
Asaf
Hi Asaf,
Do you have further question?
regards,
Farabi
