11 years agoCode is not synthesized as expected
Hi all, I have a code for registers configuration, in this code there is a "cpu interface" component which writes/reads to/from registers. The "cpu interface" drives a "cpu_wr" signal which is sent t...
11 years ago --- Quote Start --- The post is ok for this forum. I wouldn't suspect synthesis is the cause of timing failure unless proved otherwise. So let us focus on timing reports what does it actually report? is it setup violation,hold violation and which paths (internal or io). can you also post the code for those register modules. --- Quote End --- O.K thnaks, The report is for setup violation, the code is attached. Hope you will be able to explain why the "write" port goes through other registers on its way to the destination register, maybe becasue it has bidirectional data port?
