11 years agoCode is not synthesized as expected
Hi all, I have a code for registers configuration, in this code there is a "cpu interface" component which writes/reads to/from registers. The "cpu interface" drives a "cpu_wr" signal which is sent t...
11 years ago --- Quote Start --- Well, the Timequest timinig analyzer reports for failing path but this is just a warning, the synthesis is finished succesfully with- "Critical Warning: Timing requirements not met". My problem is not just the warning, i opened the thread in order to understant the attached synthesis for the attached code. Should i open it under another forum? --- Quote End --- The post is ok for this forum. I wouldn't suspect synthesis is the cause of timing failure unless proved otherwise. So let us focus on timing reports what does it actually report? is it setup violation,hold violation and which paths (internal or io). can you also post the code for those register modules.
