11 years agoCode is not synthesized as expected
Hi all, I have a code for registers configuration, in this code there is a "cpu interface" component which writes/reads to/from registers. The "cpu interface" drives a "cpu_wr" signal which is sent t...
11 years ago --- Quote Start --- Say you failed timing but you think synthesis failed. Am I right? If it is due to fan out then you can duplicate as many registers for wr as you want. But it is more helpful to present the problem as reported by tool. --- Quote End --- Well, the Timequest timinig analyzer reports for failing path but this is just a warning, the synthesis is finished succesfully with- "Critical Warning: Timing requirements not met". My problem is not just the warning, i opened the thread in order to understant the attached synthesis for the attached code. Should i open it under another forum?
