11 years agoCode is not synthesized as expected
Hi all, I have a code for registers configuration, in this code there is a "cpu interface" component which writes/reads to/from registers. The "cpu interface" drives a "cpu_wr" signal which is sent t...
11 years agoSay you failed timing but you think synthesis failed. Am I right?
If it is due to fan out then you can duplicate as many registers for wr as you want. But it is more helpful to present the problem as reported by tool.
