17 years ago
Code for optimum PLL reconfig values
running late in a project I have one quick question:
Does anyone have any pseudo code or c code for finding the PLL params for dynamic reconfiguration?
The downcounters are straight enough, but i have not found enough info for designing a program that also considers the VCO settings, Loop filter and so on.
Especially when using multiple clocks. I wrote this for a cypress pll a couple of years ago, but of course it uses a different scheme.
We happed mapped the Pll_reconfig to some registers in nios, and that works great.
Info anyone? I'll try niosforum too.
Apus
    It's been a while since we looked at it so I am afraid that I cannot help you.
    The code is not in our version control system, since it did not work.
    apus
    I agree with you altera should provide better documentation.
    I've spent 2 weeks trying to read the same document over and over again to see if i missed any important points. but still i am SOL.
    So far i have figured out how to calculate M, N and C and i understand that changing these values will give me the required fout using formula, fvc0 = (fin * M/N) and fout = (fin * M)/(n * C)
    but when i run these through PLL reconfig, my pll doesnt change.
    Weird thing is when the program first starts, due to unknown reason, my busy signal is always high!
    We gave up and used a programmable pll from cypress.
    As far as I remember we spent a fair amount of time on it before giving up.
    The reason is that the internal pll's does not follow a general pattern, they use lookup tables that are derived in lab settings and they are kept confidential by altera.
    (You migth get stable values within a certain area, but there is no way to check that at runtime)
    If you hear something else then I would be interested to know.
    Altera should absolutely make something like this available, would save time and valuable space.
    apus
    Did you ever find the answers to your question? I am having same problem and i cant seem to figure out how to calculate the values. If you have any input on this matter please help me. I have been trying to reconfigure the pll for 2 weeks now!
