15 years agocode c++
hello I have a code in c++(class: objet) can I implmente it in niosII ? regards
15 years agohi
--- Quote Start --- [/ suggested to set up a simple project in which you use the Console as alternative to the PC monitor] I try to excute many time a sample project with the prompt commad but nothing appears. --- Quote Start --- [/If you want to transfer your script.txt you could orientate to this piece of code.] it is diffiuculte to some work with mon code (simple project) ae you a tutorial more explain or can you intervenant the code?
