15 years agocode c++
hello I have a code in c++(class: objet) can I implmente it in niosII ? regards
15 years agoHi
--- Quote Start --- ... me more information for the steps (used for command prompt...) --- Quote End --- I would recommend that you start with that. Did you follow the steps Cris72 mentioned in his post? If so, have you used printf() to print something on the niosii console? Could you see something on the niosii console (^= pc monitor command prompt)? Did you try to use getc() and pressed a button on your keyboard? Could you determine the button by reading the value returned by getc()? Regards
