9 years agoClocking MAX10 and ADC at same 125 MHz frequency
I am designing a system with a MAX10 and a 125 MSPS ADC with LVDS, and I'm wondering how to handle the clocks. My plan is to clock both at 125 MHz and treat them as different clock domains, but...
9 years agoThe answer depends on your application. If it's relying on spectral purity of the ADC signal, e.g. RF or similar signal analysis applications, the ADC must be clocked directly from a low jitter source. Otherwise using a FPGA PLL generated ADC clock might be acceptable.
Thinking a bit about the data processing scheme, it should be clear that the FPGA needs a common clock source with the ADC at least for the ADC interface. Unless your application requires a second asynchronous clock source, it's pretty straightforward to use the 125 MHz as FPGA clock or derive other clocks in a synchronous manner. A minimal design would simply feed the LVDS clock to both devices. Should be possible without buffers.
