11 years agoClocked process triggered by pulse signal (VHDL question)
What I would like to do is to execute a clocked process whenever the rising edge of a pulse arrives. Here is my code:
process (pulse, clk)
variable newTrigger: std_logic:='0';
variable cnt: int...
11 years agoThen you need to synchronise the pulse with the clock
do an edge detect (register the s_pulse - synchronised pulse - and compare the registered version with current version). When you detect an edge - then reset the cnt PS. Why are you using variables? If you're a beignner, I highly suggest you use only signals.
