14 years agoClock Voltage on Max7000
Hi there! I'm doing a PCB design which includes a microcontroller and a MAX7000 CPLD. As the controller's IOs work on 3.3V we decided to run the MAX7000's IOs also on 3.3V. The core is using 5V...
14 years agoIf you read the MAX7000 data sheet thoroughly, you'll notice:
- Input buffers are supplied from VCCINT and thus independent of VCCIO. - MAX7000 inputs have a TTL level specification, minimal high level is 2.0 V. 3.3V CMOS and 5V CMOS/TTL levels are fine to drive the inputs, including clock.
