roeekalinsky
Contributor
5 years agoClock synthesis and de-skewing using an IOPLL in Arria 10
I'm trying unsuccessfully to use an IOPLL to synthesize a clock and have it be in-phase with the reference clock, where both the reference clock and the synthesized clock are routed on GCLKs. By "in-...
Ash_R_Altera
5 years agoHi,
In the Normal mode the FBCLK_IN pin of the IOPLL is fed by a CLKCTRL block whose input is driven by the FBOUT output pin of the IOPLL. The CLKCTRL block is added automatically by the tool. Hence, the FBCLK_IN is not exposed to user by the IP. You can check this in the Technology map viewer after running fitter. IOPLL User Guide mentions the following, and the tool seems to implement the same.
- If you select the normal mode, the PLL compensates for the delay of the internal clock network used by the clock output. If the PLL is also used to drive an external clock output pin, a corresponding phase shift of the signal on the output pin occurs.
Now I want to ask a question related to the measurement technique used to verify whether there is a delay between the input clock and the generated output clock or not. How are you measuring the delay between the clocks.
