15 years agoclock structure?
The cyclone ii fpga handbook says it has 4 built in PLLs. Are these associated with a particular input pin on the device? Is one of the main advantages of using a PLL on a clock input to increase acc...
15 years agook thanks.
so if I have a design in which the clock is routed into a general I/O pin (not one of the 16 clock pins), but do not need to use the PLL, will this be problematic?
