19 years agoClock Pulse Generator
Hi, I need to generate a deterministic number of clock pulses, using PLL in Stratix device. Here is what I did: PLL --> clk0 --> counter module --> clkena1 --> clk1 I developed a coun...
19 years agoHi,
Thanks for your input. Based on what you had said, if I am able to remove the clock mux, then I will be fine, right? Btw, the output of the clock mux is feeding other logic as well. From Quartus report, it seems like I can achieve ~200MHz and based on the timing analysis, no hold time violation.
