19 years agoClock Pulse Generator
Hi, I need to generate a deterministic number of clock pulses, using PLL in Stratix device. Here is what I did: PLL --> clk0 --> counter module --> clkena1 --> clk1 I developed a coun...
19 years agoHi,
Exactly per what you said, the number of clock pulses is not desired, sometime it is 1 clock pulse more, sometime few cycles more. I am developing simple counter internally to count the clock pulses and observed the counter value at the output. The clock is not going offchip. It is used internally as clock to MRAM. Previously, I created a burst counter code to take in PLL clock and upon a signal "start", it will count number of clock pulses and gate off the output. The snippet of code is shown as below: --------------------------------------------- // clock pulse counter module clockBurst ( in, out, start, count ); parameter ST_IDLE=1, ST_COUNT=2, ST_DONE=3; parameter WIDTH = 4; input in; output out; input start; input [WIDTH-1:0] count; reg [1:0] st; reg [1:0] ns; reg [WIDTH-1:0] val; wire done; always @(negedge in) begin st <= ns; end always @(posedge in) begin //st <= ns; if(ns == ST_COUNT) val <= val + 1; else val <= 0; end always @(st or start or done) begin ns = st; case (st) ST_IDLE: begin if(start == 1'b0) ns = ST_IDLE; else ns = ST_COUNT; end ST_COUNT: begin if(~done) ns = ST_COUNT; else ns = ST_DONE; end ST_DONE: begin if(start == 1'b0) ns = ST_IDLE; else ns = ST_DONE; end default: begin ns = ST_IDLE; end endcase end assign out = (st == ST_COUNT)? in : 1'b0; assign done = (val == count)? 1'b1 : 1'b0; endmodule ------------------------------------- "in" is the PLL clock. "out" is the gated clock that the number of pulses rely on "count" value. I will have "start" to trigger the clock counting Under Quartus compilation, it did show me warning message on ripple/gated clock. By using classic timing analyzer, the frequency is ~200MHz. When I ran it, it work for PLL frequency <100MHz and start to have undeterministic clock pulse when frequency go beyond 100MHz. Any ideas? Thanks a lot!
