16 years agoClock on CFI Flash Memory
Hi, i don't understand why there is not the clock pin in my flash memory. I use De2 Altera board and there is the off-chip flash memory S29AL032D. I try to use this memory without sopc builder b...
16 years agoMemory devices like S26AL032D have no clock pin.
They need no clock information as they are asyncronus devices. so there is no need to assing any clock as you won't find a clock pin at such devices to connect to so you can't change the frequency of these components. all you can do is to change the device speed by buying faster devices. the only thing you must obey is the timing relationship these devices have between several signals and these information are available from thier datesheet. thats the reason why inside sopc builder you just assign - setup - access - hold timinig values as a fpga is normaly a fully syncronus design and based upon a clock, the sopc builder calculated the counter values needed to meet these timings.
