16 years agoClock Hold warning
Hello friends, I have complete and simulate some design for MAX3000A. I have one warning I cannot avoid Warning: Can't achieve minimum setup and hold requirement clock_in along 8 path(s)...
16 years ago --- Quote Start --- Thank you pletz, I'll modify soon... But back to trouble :rolleyes:... once I assigned pins to my PLD and prepare to program'it... the timing problems went back again. Now I had -7.400nS min. slack for that 8 bus lines without LCELLs and -0.7nS with LCELLs. I need few delays more and I really don't know from where to get. Required shortest P2P 13.1nS and I have 5.7nS. I inserted a 74244 buffer but for nothing... seems compiler is so smart to ignore it. What should I do? Thanks in advance, --- Quote End --- Hi, we have to find out where the skew comes from ! Is it possible for you to post your design or parts of it in the forum, so that I can have a brief look to it ? Kind regards GPK
