16 years agoClock Hold warning
Hello friends, I have complete and simulate some design for MAX3000A. I have one warning I cannot avoid Warning: Can't achieve minimum setup and hold requirement clock_in along 8 path(s)...
16 years ago --- Quote Start --- Hello friends, I have complete and simulate some design for MAX3000A. I have one warning I cannot avoid Warning: Can't achieve minimum setup and hold requirement clock_in along 8 path(s). See Report window for details. I need max. 1MHz clock. I defined 1MHz as default Fmax and also I defined individual clock 1MHz my net with external clock(is this right?) Timing Analyzer says at Clock Hold report: Required shortest P2P 2.9nS and Actual P2P 2.6nS.... for 8 paths (it's from one verilog module to another). Now how can I deal with it? Thanks very much for further advices, --- Quote End --- Hi, can you explain more detailed how your design lookslike ? How is the clock generated and distributed ? Kind regards GPK
