14 years ago
Clock failed
I got these warnings in Quartus. Please help me fix. :)
Warning: The master clock for this clock assignment could not be derived.  Clock: pll|sd1|pll7|clk was not created.
 Warning: Specified master clock: clk not found on or feeding the specified source node: pll|sd1|pll7|inclk
    The original project and the example QAR have the same warning: :)
    Critical Warning (332148): Timing requirements not met
    I'm sorry, but I don't see this critical warning when I synthesize this.
    I attached the project with the report files (.rpt) when you look in the Static Timing Analyzer report (.sta.rpt) you will see that there is no such warning.
    Which version of Quartus are you using? The example you gave me was created for version 11.0. I use 11.1 with service pack 2.
