14 years agoClock failed
I got these warnings in Quartus. Please help me fix. :) Warning: The master clock for this clock assignment could not be derived. Clock: pll|sd1|pll7|clk was not created.
Warning: Specifie...
14 years agoOk, in this case you need to modify or create a SDC file.
Here is an example which creates timing constraints for the 25 MHz input clock "clk_pin":
create_clock -name clk -period 25MHz
# derive PLL output clocks & add clock uncertainty
derive_pll_clocks -create_base_clocks
derive_clock_uncertainty
