TAdel1's avatar
TAdel1
7 years ago
Clock divider simulation problem
Hello there ,
I tried to code this clock divider to divide my input clock by 16 , but when I run simulation I got my output signal period same as my input clock , any one please can tell me why that happened ? my code
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY TRICK IS
PORT ( CLK : IN STD_LOGIC;
F : OUT STD_LOGIC);
END TRICK;
ARCHITECTURE BEH OF TRICK IS
SIGNAL CNT : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
PROCESS (CLK) IS
BEGIN
IF (CLK'EVENT AND CLK='1') THEN
CNT<= CNT + 1;
ELSE
CNT<=CNT;
END IF;
F<=CNT(3);
END PROCESS;
END BEH;
  • Vicky1's avatar
    Vicky1
    May I know any update?
    Should I consider that, case to be closed?
    Vicky
  • Vicky1's avatar
    Vicky1
    what you observed in simulation result? please provide screenshot.
    Have you initialized the inputs(CLK) & outputs(F,CNT) in testbench?
    Vicky
