16 years agoClock control block
I need detailed information about clock control block, Can some one help me?
And how to set clock select for a clock control block in programming file(.SOF or .POF).2 Replies
--- Quote Start --- Hi, for detailed information look into the clock chapter of your device in use or in the documentation of the clock control block in the Megawizard. You can`t change the selection directly in the pof or sof, this has to be done in your design. Kind regards GPK --- Quote End --- I forgot to post the link to the userguide: http://www.altera.com/literature/ug/ug_altclock.pdf Kind regards GPK - Altera_Forum
--- Quote Start --- I need detailed information about clock control block, Can some one help me? And how to set clock select for a clock control block in programming file(.SOF or .POF). --- Quote End --- Hi, for detailed information look into the clock chapter of your device in use or in the documentation of the clock control block in the Megawizard. You can`t change the selection directly in the pof or sof, this has to be done in your design. Kind regards GPK
