16 years agoClock control block
I need detailed information about clock control block, Can some one help me? And how to set clock select for a clock control block in programming file(.SOF or .POF).
16 years ago --- Quote Start --- I need detailed information about clock control block, Can some one help me? And how to set clock select for a clock control block in programming file(.SOF or .POF). --- Quote End --- Hi, for detailed information look into the clock chapter of your device in use or in the documentation of the clock control block in the Megawizard. You can`t change the selection directly in the pof or sof, this has to be done in your design. Kind regards GPK
