clk_pll input location for DDR4 HPS (arria10sx066f34I2SG)
Hi I'm working on the device mentionned in the title.
I'm using a board from a third party vendor, but I'm facing a problem concerning the input clock of the HPS ddr interface.
When trying the plan stage, Quartus(19.3pro) don't let me place this pin at the location AL27 resulting in an error. I don't understand why Quartus doesn't want to fit this pin at this particular location as there is no explanation in the error tab.
The problem is that I can't place this particular pin at the proposed location because it's already binded to another clock of the board.
Thank you for your help
Hi there,
I apologize for the late reply, due to Lunar New Year.
Please try the following:
- You will need below INIs variable :
• emif_restrict_hps_refclk_to_ac_tile=off
1. Open the fitter_error.qar file, add the INI file with emif_restrict_hps_refclk_to_ac_tile = off.
2. Then re-check the fitter.
Could you please try using these INIs and let us now if the error disappears when placing an HPS-EMIF?
2. If not, could you try using Quartus 19.1 if are you seeing the same error? Please let us know if the error the same when using Quartus 19.1.
Regards.
- BJona
Hi el.ign,
thank you for you reply, this solved my problem.
John
- BJona
Hi sstrell,
I understand, I think this is a conception bug.
- EBERLAZARE_I_Intel
Hi there,
Regards.
- sstrell
For HPS DDR, you have to use specific pins for a specific I/O bank since the interface is all hardened and dedicated to the HPS. If there's already a clock not used by the memory interface going into that particular pin, you'll have the issue you're seeing.
#iwork4intel
