Clarification on BGA Ball/Pin Pattern for Altera FPGA Devices
Hi Team,
We are created PCB footprints for the following Altera FPGA devices:
- AGIB022R31A2E2VCNL – BGA-3184
- A3CY050BB18BE7S – BGA-538
- A3CY135BB23CE7S – BGA-931
While reviewing the manufacturer package drawings and creating the footprints, we observed that the ball/pin pattern uses different pad arrangements and the pitch between the pins/balls is not uniform in some areas.
Could you please clarify whether there is a specific design or manufacturing reason for using these different ball/pin patterns and pitch arrangements?
1 Reply
- ai_responder
Community Manager
Good question — the different ball patterns and non-uniform pitches across all three packages are intentional design choices driven by both electrical performance requirements and PCB routability goals. Here is the breakdown per device.
AGIB022R31A2E2VCNL — R31A, 3184 balls (Agilex 7 I-Series)
Agilex 7 uses a rectangular package with a hexagonal (hex) ball array pattern, chosen specifically for more functionality per area. 1.1. Key Features and Innovations in Agilex® 7 FPGAs and SoCs — Agilex® 7 FPGAs and SoCs Device Overview The packaging employs EMIB (Embedded Multi-die Interconnect Bridge) technology and uses a mixture of ball pitches — 1.025 mm, 0.92 mm, and several mixed-pitch packages. Table 2. Feature Summary — Agilex® 7 FPGAs and SoCs Device Overview For the R31A package specifically, the pitch is 0.92 mm 2.6. Package Comparison Tables — Agilex™ 7 FPGAs and SoC FPGAs Package, Pinout, and PCB Design User Guide , and the I-Series family pin floorplan is a HEX pattern with 0.92 mm and 1 mm pitch 6.5.5. Agilex 7 F-Series and I-Series EMIF-Specific Routing Guidelines for — External Memory Interfaces Agilex™ 7 F-Series and I-Series FPGA IP User Guide — the 1 mm pitch appears in areas such as the R-Tile boundary. The I-Series R31A contains R×1 and F×3 tile configuration 2.3. Series/Package/Tile Comparison Table — Agilex™ 7 FPGAs and SoC FPGAs Package, Pinout, and PCB Design User Guide , and the pitch variation between regions reflects the different electrical requirements of the R-Tile (PCIe/CXL high-speed) and F-Tile (high-speed transceiver) pin fields relative to the GPIO/fabric areas. The hex ball array packs more balls into the same body area compared to a square grid, enabling the high I/O density at the 56×45 mm body size.
A3CY050BB18BE7S — B18B, 538 balls (Agilex 3 C-Series)
A3CY135BB23CE7S — B23C, 931 balls (Agilex 3 C-Series)
Both of these use the VPBGA (Variable Pitch Ball Grid Array) package type. Agilex 3 FPGAs and SoCs are available in variable pitch ball grid array (VPBGA) and micro fineline ball grid array (MBGA) packages. 1.1. Agilex® 3 FPGAs and SoCs Packages — PCB Design Guidelines Most Agilex 3 device packages use the VPBGA design, which you can identify through the package code starting with "B". 2.1. Device Footprint — Cyclone V to Agilex™ 3 Device Migration Guide
The variable pitch is deliberate:- The VPBGA package has variable ball pitch sizes in a single package to ease signal routing. 1.1. Agilex® 3 FPGAs and SoCs Packages — PCB Design Guidelines
- Compared to standard grid BGA packages, VPBGA packages have a smaller form factor and fewer board signal routing layers but provide the same number of I/O pins and compatible electrical performance. 1.1. Agilex® 3 FPGAs and SoCs Packages — PCB Design Guidelines
- The VPBGA package is compatible with low-cost Type III PCB design with design rules equivalent to a 0.8 mm ball pitch package with standard plated through hole (PTH) vias. 1.1. Agilex® 3 FPGAs and SoCs Packages — PCB Design Guidelines
For the B23C package (A3CY135BB23CE7S): B23C is a 23 mm × 23 mm VPBGA with ball pitch ranging from 0.5 mm to 0.94 mm. Table 1. Agilex 3 BGA Packages — PCB Design Guidelines The A3C100 device in package B23C uses a VPBGA package with different ball pitches in different BGA functional areas, ranging from 0.5 mm to 0.94 mm. 4.2. Pin Distribution and Ball Pitches Package B18B/B23C — PCB Design Guidelines
The different pitch zones within a single package each serve a specific purpose:- The 0.5 mm ball pitch is optimized to have one signal trace routing through on the top layer 4.4. Fan-Out and Routing Strategy B18B/B23C — PCB Design Guidelines , enabling escape routing without additional PCB layers.
- Wider ball pitch, up to 0.94 mm (and 1.45 mm in B18A), allows routing of more signal traces compared to standard grid BGA packages, helping reduce the number of PCB layers and keeping board cost low with Type III PCBs. 14. Variable Pitch BGA (VPBGA) Package Design of Agilex™ 3 FPGAs and SoCs — Agilex™ 3 FPGAs and SoCs Device Overview
- The 0.5 mm or 0.94 mm ball pitch for high-speed transceivers is optimized for high-speed signals. 4.7.1. HSSI Pin-Field Breakout for VPBGA — PCB Design Guidelines
- Power pins for Agilex 3 VPBGA devices are mainly located in the center BGA area, and there are also some GPIO pins at the edge of the center area to ease signal trace routing. 4.6. Power Pins — PCB Design Guidelines
For your footprint creation, make sure to reference the Package Ball Coordinates spreadsheets (available for B18B and B23C) for the exact X/Y ball locations, and use the recommended BGA footprints from the PCB Design Guidelines. For reference, note that the MBGA package has a fixed pitch size 4. VPBGA PCB Routing Guidelines — PCB Design Guidelines — only the VPBGA packages carry the variable pitch behaviour described above.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
