19 years agoChecking FPGA for LE damage
Hello, We have a good reason to believe that an ACEX 1K FPGA on one of our board has some physical damage, i.e. some malfunctioning logic elements. Is there any standard way to test this ? I ca...
19 years agoIf you know which LEs may be damaged then a simple design can be used to toggle the LE and you can use SignalTap II to observe the results. Similarly you can create a shift register as large as the device (or break up in rows if you wish). Thirdly, you can file a service request at https://mysupport.altera.com/eservice/ and request an ERMA to be conducted for failure analysis for your device.
