14 years agoChanging the speedgrade
Our project is working with EP3C25F324C6 (6nsec). To save money there is a push to change to EP3C25F324C8 (8nsec). Will it work? :confused: (Sorry, thats a dumb question, without nearly enough...
14 years ago(Note that the speed grades don't refer to ns anymore, they're just relative indicators of performance).
Without timing constraints, how did/do you know the design works in a -6? If it's a valid test, then do the same test on the -8. If it wasn't a valid test, then you don't know about either. Learning how to do core timing is pretty easy. Take a look at the TimeQuest User Guide I have on alterawiki, and the first chapter is a Getting Started. The I/O constraints are more difficult and take time, but also one of the things that is often likely to fail.
