8 years agoChanging single GPIO Pin output voltage
Hi, I am trying to do connect a video camera (OV7670, from Omnivision) on altera DE2 (EP2C35F672CN - Cyclone II). I got stuck on one question: I would like to avoid using external circuitry to...
8 years agoThank you for the information. I tried to change the Bank voltage for 1.8V in GPIO_1 bank for using just only one pin from it and the rest from GPIO_0. I measured the voltage from the pin and it still has 3.3V . Is there something that I did wrong? Or when you said that external circuitry is required, you meant that changing the IO bank on Quartus II will not reduce the output voltage ?
Regards, Marcio --- Quote Start --- Hi, This error occurs when a bank is using vccio=3.3V and we try to use 1.8 V for one/ more pins in the same bank in your design.- We can't change voltage for a single pin in the Bank, You can change the VCCIO for the entire bank.
- External circuitry is like a level shifter are required.
