8 years agoChanging single GPIO Pin output voltage
Hi, I am trying to do connect a video camera (OV7670, from Omnivision) on altera DE2 (EP2C35F672CN - Cyclone II). I got stuck on one question: I would like to avoid using external circuitry to...
8 years agoHi,
This error occurs when a bank is using vccio=3.3V and we try to use 1.8 V for one/ more pins in the same bank in your design.- We can't change voltage for a single pin in the Bank, You can change the VCCIO for the entire bank.
- External circuitry is like a level shifter are required.
