14 years agochanging floating license port speeds compile
Why would changing the floating license port from 1819 to 1820 speed up Quartus compileing times?
14 years agoThe problem comes when students change this port (see below), then ModelSim does not work;
Prof., After some digging around, it seems that editing the license file prevents quartus from long delays before it will compile. (Perhaps it tries to ping the wrong server at first?) I opened up c:\altera\license.dat in a text editor and changed the last number on the first line from 1819 to 1820 The file now reads: > SERVER licsrv.engineering.cornell.edu 00505694574A 1820 USE_SERVER > This seems to have shaved a full minute off the compile time (a factor of 2 speedup for the last project)
