14 years ago
changing floating license port speeds compile
Why would changing the floating license port from 1819 to 1820 speed up Quartus compileing times?
    Choon Lee,
    We found the answer. Change the license.dat on the client computer to point to port 1820 (for Quartus compile speedup) . Then, change the ENV variable on the client computer to point to port 1819 (for ModelSim license). Compile speeds are down to ~30 seconds, and ModelSim can find it's license. All works fine now.
    Thank you,
    Doug
    The problem comes when students change this port (see below), then ModelSim does not work;
    Prof.,
    After some digging around, it seems that editing the license file prevents quartus from long delays before it will compile. (Perhaps it tries to ping the wrong server at first?)
    I opened up
    c:\altera\license.dat
    in a text editor and changed the last number on the first line from 1819 to 1820
    The file now reads:
    SERVER licsrv.engineering.cornell.edu 00505694574A 1820
    USE_SERVER
    This seems to have shaved a full minute off the compile time (a factor of 2 speedup for the last project)
    Here is the result of that;
    C:\Windows\system32>lmutil lmstat -a -c 1819[at]ourlicenseserver.cornell.edu lmutil - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corp
    oration. All Rights Reserved.
    Flexible License Manager status on Wed 10/19/2011 10:11
    [Detecting lmgrd processes...]
    License server status: 1819[at]EN-LICSRV
    License file(s) on EN-LICSRV: 1819[at]ourlicenseserver.cornell.edu :
    lmgrd is not running: License server machine is down or not responding. (-96,7:1
    1001 "WinSock: Host not found (HOST_NOT_FOUND)")
    Any ideas?
    you could try lmutil lmstat -a -c port@server with the bad port and good port and see if the server has a bit of latency on the bad port
