17 years agoChange path name in qsf to sdc
Hi I tried to change path name in TimeQuest's Summary. so I used "set_instance_assignment -name" in qsf. Like that. set_instance_assignment -name CLOCK_SETTINGS WR_CLK -to ip_clk # WR_C...
17 years agoHi,
yes , I use "derive_pll_clocks -create_base_clocks" in sdc. popurse of using is Mega_wizard setting reflect automaticaly in sdc. I hesitated to use "create_generated_clock". and,I want to change more readable any signal in sdc. example is //********************************************************************** 1. set_multicycle_path -end -setup -from [get_keepers {average_calc:average_calc|r_avr_data [*]}] -to [get_keepers {average_calc:average_calc|r_mul_data [*]}] 2 2. set_output_delay -max 2 -clock pll|altpll_component|pll|clk[1] [get_ports out_data [*]] //********************************************************************** How can I make shorter "average_calc:average_calc|r_avr_data [*]" and "pll|altpll_component|pll|clk[1]"?
