17 years agoCell Automat
I have been working at the projetc where it is expected to create "logical space" associated with biological and chemical environment.Where each molecule or couple of them are assiciated with infor...
17 years agoFor "automatic information flow control inside fpga from windows" I guess it is very unlikely you will find any ready-made work. You will certainly need nios module to interface with a window module. You will need to write both modules yourself I am afraid. The nios module can interface to fpga through a register stack that you must build in firmware.
I am not sure, however, why use fpga in the first place. You can do it in software all. FPGA only gives the advantage of speedier data-intensive processing at the expense of low complexity algorithms.
