16 years agoCDR Solution for 2Mbps 8B10B data stream
Hi there, Is there a way to generate a phase locked 2MHz clock from a 2Mbps 8B10B data stream? All the CDRs I can find are made for higher bit rates. I thought it would be easier for lower bit ...
16 years ago --- Quote Start --- There's another option to use the PLL dynamic phase shift option present e.g. in Cyclone III FPGAs to build a software CDR. It can work up to 100 or 200 MBPS speed. But I'm not aware of an Altera reference design demonstrating this method.. --- Quote End --- Does the soft-CDR work at 2Mbps bit rate? Thanks, Hua
