vkc
5 years agoCDR in automatic mode
Hii , i am using stratix 4 fpga in our design. I am using CDR in automatic mode. i followed the reset signalling according to the manual. so rx_freqlocked and pll_locked is high but rx_plllocked is ...
Deshi_Intel
5 years agoHi,
If you sync status is high, that means you already achieved synchronization and likely this is bit error issue which correlate to 8b/10b decoder status error signal rx_errdetect and rx_disperr that are toggling.
- The recommended approach to debug bit error is always to start to perform FPGA internal loopback testing to isolate whether this FPGA design issue or board design issue
- If you have debug and pointed to likely your board design issue then one quick suggestion is to reduce your data rate speed to see if it helps
The other concern I have is what's your design rx_plllocked connected to ? pll loose lock is never a good sign and you should fix this issue first else functionality failure is expected as the PLL can't generate expected clock output in stable stage.
- Are you using NativePHY or which IP that you are using ?
dlim
vkc
5 years agoI am using altgx ip.I have not connected rx_plllocked to anything in design.To what is rx_plllocked suppose to be connected.
