9 years agocarry chain delay difference between real test and Timequest analysis result
Hi all, 5CGXFC7D6F31C7N is used to implement a TDC in my design with QII14.0. according to timequest analysis results, the average carry delays of adder in a ALM are 52ps, 46ps, 27ps, 26ps respe...
9 years ago --- Quote Start --- I have heard about TDC on FPGAs but I have doubts about its precision as it should take into account clock tree delays, timing violations, fitting variation, optimisation and needs some sort of averaging --- Quote End --- Thanks for your reply. Well, as you look into FPGA based TDC implementation, you will see that these problems you said all will be handled commendably. Here my problem is not how to implement TDC in FPGA, my problem is why TimeQuest analysis result is different from real test. Since TimeQuest plays a critical role in regular FPGA designs, i need to figure out what is wrong? is my test result wrong? or something else. I have used the same method to acquire the carry delay of Cyclone-IV, the real test result is well fitted into Timequest analysis result, while for Cyclone-V, this is not the case. I think the problem could be replicated easily, i need a confirmation from someone else. Best Regards, ingdxdy
uv_rok
3 years agoHi, I am Making a TDC in Cyclone 4E device. I created the carry chain successfully but I am not able measure the carry delay. Can you help me by telling how to measure average carry delay by Feeding pulse and by TQ analyser. Pls share some reference design
