18 years agoCan't resolve multiple constant drivers for net "next_state"
Dear Sir,
I am writing one simple program for traffic signalling. I got the following error. Error (10028): Can't resolve multiple constant drivers for net "next_state" at traffic.v(43) can anyone help to solve this problem?? the code is below: `define GREEN 0 `define YELLOW 1 `define RED 2 module traffic(R, G, Y, clock, reset); output R, Y, G; // Red, Yellow, Green Signal lines input clock, reset; reg next_state; reg R, Y, G; always @(posedge clock) begin case (next_state) `GREEN: begin next_state = `YELLOW; G=1; R = 0; end `YELLOW: begin next_state = `RED; Y=1; G = 0; end `RED: begin next_state = `GREEN; R = 1; Y = 0; end endcase end always @(reset) next_state =`RED; endmodule //4 Replies
Hi, thanks for clearing my mind about this error. My fsm compiled and simulate success in modelsim but switch to quartus it shows this error. Cheers
I think the reason for the error message is that there are two events which can affect the value of nextstate which are not mutually exclusive. Consider what would happen if there was a positive edge on clock at the same time that reset changed. What would nextstate become?
I'd use a synchronous reset, i.e. always @ (posedge clock) if(reset) begin // Reset nextstate end else begin // State machine case statement end If you re-order your code in this way you might find it works. - Altera_Forum
you'll need to change the line "module Verilog_Traffic" to "module traffic"...sorry about that.
This is slight modification of your code, it works, and is a different approach to writing state machines in verilog:
module Verilog_Traffic(R, G, Y, clock, reset); output R, Y, G; // Red, Yellow, Green Signal lines input clock, reset; reg R, Y, G; //state machine parameters reg [1:0] present_state, next_state; parameter Green = 2'b00, Yellow = 2'b01, Red = 2'b10, Reset_State = 2'b11; always @ (posedge clock) begin if(reset) present_state = Reset_State; else if (~reset) present_state = next_state; end always @ (present_state) case (present_state) Green: begin G = 1'b1; R = 1'b0; next_state = Yellow; end Yellow: begin Y = 1'b1; G = 1'b0; next_state = Red; end Red: begin R = 1'b1; Y = 1'b0; next_state = Green; end Reset_State: begin R = 1'b0; Y = 1'b0; G = 1'b0; next_state = Red; end endcase endmodule
