8 years agoCan't load .jic file to EPCQ device
My custom board is equipped with the Cyclone V FPGA and the EPCQ128 configuration device. I use Quartus 17.1.0. I convert the .sof programming file to .jic having the Active serial x4 option se...
8 years ago@Anand, thank you for your reply.
After cross-check of the PCB design files, it turned out, the MSEL[4:0] were not set properly set in the Active Serial Fast mode. The issue has been solved. Thank you.
