10 years agocan't find the pin assignments for my EP2C70F896C6N FPGA
hello, I have EP2C70F896C6N and trying to program it using Quartus II. I made new project with block diagram file, i compiled it and programmed it to FPGA using JTAG mode. the FPGA successfull...
10 years ago --- Quote Start --- hello, I have EP2C70F896C6N and trying to program it using Quartus II. I made new project with block diagram file, i compiled it and programmed it to FPGA using JTAG mode. the FPGA successfully programmed but the program didn't work. like i have the wrong pin Table for switches and Leds. is there a static pin table for my FPGA or can i set the pins for each switch and led. thank you! --- Quote End --- If you are using a dev kit, you can download the kit installation at altera's website(https://www.altera.com/products/boards_and_kits/all-development-kits.html). It is a pretty comprehensive kit. You can find the reference manual, user guide, schematic and many more documentation in it.
