can't define differential clock at MAX10
Hello Moti,
May I know which version of Quartus are you using?
Try this workaround to solve Error 169029:
1. Remove the location assignment of pin_perst
2. Add a quartus.ini file in your project directory with: dft_skip_oct_vccn_check = on
Try this workaround to solve Error 169032
1. Assign 1.5V PCML I/O standard to Cyclone IV GX transceiver input pins.
Thank you.
Thanks AminT for the fast response.
the version is Quartus standard 19.1,
I added the quartus.ini file and define the clock pin as Sub-LVDS, the 2 error are gone ( 169029 & 169032 ).
what causes the error in Quartus ?
but still the question is technical, can I now connect to the Max10 differential clock (of 1.8V at bank of 1.8V
and there is no any Vref from the pins to the CPLD) and define it as LVDS ? Sub-LVDS ?
Do they require Vref ? and what with others differential I/O 's ?
Thank you
- AminT_Intel5 years ago
Hello Moti,
The error is a known issue. You will need to refer to these two documents for your design I/O standard specification: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-gpio.pdf and https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/s10_datasheet.pdf .
Thank you.
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
