Can't connect to JTAG on EP4CE6 Mini Board
Product ID is dependent on Vendor ID. So even if the Product ID is the same, if the Vendor ID is not correct, it will not be detected.
On my Terasic FPGA board that implements an embedded USB Blaster, I see this:
Device Descriptor:
bcdUSB: 0x0110
bDeviceClass: 0x00
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x08 (8)
idVendor: 0x09FB (Altera)
idProduct: 0x6001
bcdDevice: 0x0400
iManufacturer: 0x01
iProduct: 0x02
iSerialNumber: 0x03
bNumConfigurations: 0x01
Same data for my standalone Terasic USB Blaster clone. So unless you can change to the correct Altera Vendor ID in the hardware (0x09FB) OR change your USB driver install files to look for your different VendorID (0x0403) your hardware will not be recognized.
