rewingchow
5 years agoCannot Program Stratix 10 MX board Anymore (Error Status: 18952)
After an attempt to program the Intel Stratix 10 MX board, which failed 17% into programming, every attempt to program fails from the beginning. Before the fail at 17% the board would program complet...
NurAiman_M_Intel
5 years agoHi,
- Have you successfully program the FPGA previously?
- Make sure the JTAG communication cable(s) are securely connected to the target system and are set to use a JTAG TCK frequency that is supported by all the devices in the JTAG chain and the target system, and the correct device is selected. Then retry the operation.
- On top of that, has you try to program other working FPGA on the board to see if it was program successfully? This is to see if the the board is working fine or not.
- Also, has you try to program the Stratix 10 with other PC?
Aiman
