Cannot access the JTAG port of Arria10 SoC
- SYiwe7 years ago
Thank you. Here's my update.
The waveforms of both devices' nSTATUS pins are rectangular waves, and one's frequency is 516Hz while the other one is 542Hz.
I refer to relevant hanbook, after sampling MSEL, nSTATUS is released high and then pulled low if configuration error occurs.
In my design, I define MSEL=011 with pull-up resistor to VCCPGM and pull-down reststor to GND, which indicates AS×4 mode. Each of the devices has an attached EPCQL1024.
Is it possible that the devices try to load configuration data from EPCQL1024 after power-up then fail, so the waveform of nSTATUS is rectangular wave, resulting the reset of the device and JTAG periodically?
If the answer is yes, how can I solve this problem to relase the device from reset state?
Thanks, regards.
