TMayd
7 years agoCan you use the non-volatile key from the FPGA (Cyclone V) in a design?
So we would like to use the fused non-volatile key in the Cyclone V to provide our application with a seed for an SHA-256 algorithm. It's not clear to me if you can set this fuse and then access the ...
- 7 years agoHi TMayd, Yes, the programmed non-volatile key is use to decrypt the configuration bitstream during the configuration process. The general process flow is shown in figure 1 from AN556. Once you program the non-volatile key, is it OTP, there is no way to repogram with a different value. You can generate multiple key files and encrypted image files . However once you program the non-volatile key into Cyclone V, the decryption engine can only decrypt the matching encrypted image. Regards, Nooraini
Nooraini_Y_Intel
Nooraini
