9 years agoCan you sovle the CPLD?
Good afternoon~:)Are there any manipulators in here? OK,let’s go into the subject directly.Now let me describe the questions about counting process of the three way external pulse by used cpld ...
9 years ago1) Implement your pulse counting logic in the FPGA (in verilog or vhdl, as you desire). Your requirements above seem pretty clear.
2) Implement a SPI interface in the FPGA (again, in your language of choice). A SPI interface is a pretty simple logic implementation. 3) Write a testbench to test your FPGA code functionality (ie, write a SPI master controller and have it read/write your FPGA registers). 4) When you are pretty confident it seems to work, compile and program into an FPGA, and then connect to your CPU board and check it. 5) Go back thru the loop to (1) when things don't seem to work. Once you have some code written, we can comment on it and help you debug it. But we won't write it for you.
