15 years agoCan we use a differential clock input as 2 single-ended clock inputs?
I use a FPGA of the Stratix GX II family, EP2SGX90FF1508.
In my design I have 3 differential input clocks on an external connector but I actually need 5 single ended clock inputs. Is it possible to use a differential input as 2 single-ended inputs? Do we need to configure something on Quartus for that? Thanks for you help!1 Reply
--- Quote Start --- Is it possible to use a differential input as 2 single-ended inputs? --- Quote End --- Yes. --- Quote Start --- Do we need to configure something on Quartus for that? --- Quote End --- Assign a single ended I/O standard and the respective pin location for the clock signals.
